I accidentally flashed s32k14x with s32k11x example in the MBDT and I am having trouble flashing the s32k14x again.
Is there any solution to solve this?
解決済! 解決策の投稿を見る。
Did P&E Recovery Utility work? https://community.nxp.com/t5/S32K/Can-t-use-PEmicro-debugger-with-S32K118EVB2-Q048/td-p/1376204
Have you tried MSD Flash Programmer?
Or Select the Emgerency Kinetis Device Recovery by Full Chip Erase.
Robin
Hi Robin,
P&E Recovery Utility did the trick.
Thanks!
