LIN Conformance Test with S32k148evb using Vector CANoe
kmuh
hello all,
i'm doing a LIN conformance (compliance) test using Vector CANoe and i'm facing this issue , so what should be the reason for it and what is the solution ?
in test cases PT-CT88,89,90,93.
IUT has not responded to diagnostic request
nxf78987
Hi @kmuh,
Could you provide some information as below?
  • Hardware.
  • Software release version.
  • The ldf file is used for testing.
  • CANoe version.
  • CANoe's logs of frames sent on bus with failed test case.
Dan
