We test our project on our own demo board, when we set the core clock to 160MHz, it runs fine with GPT module ( just to toggle a LED light ), but when we set the core clock to 240MHz, it can't run properly, in can only run with this function (Mcu_DistributePllClock()) blocked.
But we can run the project with 240MHz fine on the NXP official demo board.
What do you think is the problem or which aspect we should look into?
If the same project can only run on the official NXP demo board, then I think the possible problem lies in the hardware. You can check the external crystal oscillator on your board and compare the difference with the official board.
We tried move our demo's crystal oscillator to the official demo, no problem. But we moved the official demo's to our demo, still not working. Still trying to find the solution.
Can you provide more information, such as your hardware schematic and test routines?
You can send me a private message and I will help you double check it.
