Issue No:-1)
We are using attached file for bootloader and application is hello world from example code.
Before jump we have followed below procedure.
1)Disable all interrupt.
2)Deinit CAN and timer.
For boot to app jump we are using below instructions.
App_Vector_Table à 0x10000. (you can refer in attached lsl)
S32_SCB->VTOR = (uint32)0x10000;
__asm(" ldr r1, = 0x10000"); // get the stack pointer value from the program's reset vector__
__asm(" mov sp, r1");
__asm(" ldr r1, = 0x10004"); // get the program counter value from the program's reset vector
__asm(" mov pc, r1"); // jump to the start address }
After jumping to application we are facing problem of WatchdogIRQ.in both case we are getting same result.
Issue No:-2)
Case 1:-Flash the boot ,close S32 software and remove debug cable working fine.
Case 2:- Flash the boot ,close S32 software, remove debug cable and perform power cycle(Power OFF and ON)it is not working
解決済! 解決策の投稿を見る。
1. What exactly happens after the jump into the application?
2. Do you use your own bootloader? Can you share your project?
Thank you.
Diana
Thank you.
Diana
