Interrupt LPSPI on Davinci configurator pro error
已解决
跳至解决方案
3,311 次查看
MyLV
I am configuring for SPI on Davinci Configuration Pro for S32K344.
now I am facing with Interrupt trouble, Interrupt not triggered.
In this case, using LPSPI_0 and Isr Interrupt source filed is 165 as S32K3xx_interrupt_map.xlsx attached file inside RM file.
please give me suggestion?
1 解答
3,286 次查看
cuongnguyenphu
Have you enable ISR for LPSPI in your code yet?
I'm not sure how Davinci tool generate, but I think you only config for the ISR handler by Davinci Tool, but maybe you haven't enable this ISR in the code.
You should check the NVIC register for sure
在原帖中查看解决方案
2 回复数
3,287 次查看
cuongnguyenphu
3,273 次查看
MyLV
Hi @cuongnguyenphu
Thank you for replying.
I already resolved that one.
In case of Microsar configuration on Davinci we need to use Vector(All Cores) instead of IRQ value.
In this case, I configured 181 rather than 165.
