I want to implement real-time PWM duty cycle change with DMA, Is there any demo you can give me for
Zhuang
I have tried to configure myself, but have failed, NXP can give me some reference
Senlent
Hi@Zhuang
you can refer to this article which is all i can find for your topic.
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K118-FTM-PWM-DMA-S32DS-2-2/ta-p/1342183
Zhuang
I tried to follow this routine, but in the process I ran into a problem: I was passing data through DMA 10 10 10 0. Here in the figure, it should be 0 but it appears 1, I do not know whether the DMA did not transmit the number or the PWM did not update, how to check this?
Senlent
Hi@zhuang
I don't know how you get the picture you provided and you can take a look at the chapter
Zhuang
This is my configuration
Senlent
HI@zhuang
This is no different from the demo configuration I provided to you.
I suggest you create a separate project to test this feature. You can add some flag bits for DMA transfer completion and PWM synchronization completion, and use a logic analyzer to analyze these timings.
Zhuang
Hi Senlent,
I want to confirm, how to confirm the completion of PWM synchronization?
Senlent
Hi@Zhuang
I read the relevant content, and there seems to be no flag bit when the hardware triggers synchronization completion.
Zhuang
In addition to increasing the flag bit after the completion of DMA transfer, what other feasible measures?
Zhuang
I have now made some DMA complete transfer flag, only the flag set will allow the next send.
Now I want to confirm, how to confirm the completion of PWM synchronization?
Zhuang
I use Init_trig (CNT set 0) to trigger FTM output waveform change, FTM has waveform change, CHF set, trigger DMA so.
Zhuang
I used an S32K148
