How to realize CAN3 communication
954 次查看
JackChen2022
The s32k148_144 chip needs to use four channels of CAN communication at present. Can0, can1, and can2 are directly realized through the can component configuration function of S32DS. Can CAN3 be realized through GPIO function multiplexing? Please provide some suggestions and reference materials
919 次查看
Cookmark103
Scentsy Workstation Login: Today, we will look at the Scentsy workstation and its information. We’ll go over all the essential information regarding this working station, your login requirements, the procedure for resetting your password, and contact details to help you with any issues you may encounter while using the dashboard login.
Also Read: Scentsy Workstation Login
933 次查看
Senlent
Hi@JackChen2022
       Do you mean to simulate CAN communication through GPIO? This is a bit difficult to implement, so far I have not encountered such a use case.
922 次查看
JackChen2022
Yes. On the s32k148_144 chip, our project currently requires four-way CAN communication. Is there a way to achieve it?
