How to generate different frequency on different channel of same FTM
1,385件の閲覧回数
nitinverma
Hello support team,
I am working with SD32k144 evaluation board.I have application to generate the PWM signnal of different frequency on different channels of single FTM.
I am not able to do it.Kindly help me ASAP.
2 返答(返信)
1,124件の閲覧回数
nitinverma
Thanks a lot Ptre for your prompt reply.
1,124件の閲覧回数
PetrS
This is not possible. The FTM contains single 16-bit counter for whole module. It can define PWM period using initial and final value. Then each channel has just Channel Value register that determines the match value for the output modes.
BR, Petr
