How to create a software reset without use the watchdog
3,830 次查看
sebastien_ledio
Hello community,
I am working on NXP S32K146, and I would like, by software, to create/generate a reset without watchdog, because I did not use it.
By advance, thanks for your answer.
Sebastien
3,132 次查看
dianabatrlova
Hi Sebastien,
I would like to add the note that you do not need to create an SDK project. This information can be found in the Cortex™ -M4 Devices Generic User Guide - 4.3.5 Application Interrupt and Reset Control Register
http://infocenter.arm.com/help/topic/com.arm.doc.dui0553b/DUI0553.pdf
The code below will trigger software reset
S32_SCB->AIRCR = S32_SCB_AIRCR_VECTKEY(0x5FA) | S32_SCB_AIRCR_SYSRESETREQ(1);
Diana
3,132 次查看
Yunchuan
you can call void SystemSoftwareReset(void)  to create/generate a reset, path: project path/SDK/platform/S32K146/startup/system_S32K146.c
