I am using S32K344 EVB, and found that the pin VRC_CTRL is not controlled. Do I need to pull it up ? If I do not control whether it affects the function of the MCU. I found that this pin has PG_VRC_CTRL mode in EB, but not in S32 CT.What should I do, I look forward to replying.
解決済! 解決策の投稿を見る。
Hello @jacst,
I'm not sure if I understand.
But the PTE13 pin is routed to PG, VCR_CTRL by default out of reset.
So, the CT does not need to configure the pin at all in this case.
Hello @jacst,
