How can I get the wakeup resource In S32K142 after The chip exits Stop or VLPS Mode?
Jinyuxin
In my project of S32K142, There are some wakeup resources,such as Can、Pin interrupt、WDTG and so on,but How can I get the real wakeup resource after S32K142  is wakeuped?
danielmartynek
Hi @Jinyuxin,
You need to identify the interrupt within the ISR.
This is not much of processing.
Jinyuxin
Hello Daniel:
Thank You Very Much.
danielmartynek
Jinyuxin
Hello Daniel:
Thank you for your answer,at first.
Must I put  the  getting wakeup resouce process in each ISR Function?
Can I put this processing after the calling of POWER_SYS_SetMode(VLPS, ..)?
Thank you.
danielmartynek
Hi @Jinyuxin,
