Hard fault during hse firmware install
581件の閲覧回数
vikmonti7804
    We flashed the hse firmware in the mcu and also We are initializing the MCU clock in our bootloader firmware. after reset the mcu I am experiencing the hard fault in MCU clock init from register level.
Then i commented the MCU clock init in bootloader firmware and then program is running without any hardfault.
Does it mean HSE is initializing the clock inside its firmware?
Or what can be reason for the hard fault, any clue?
please provide answers.
タグ(1)
7 返答(返信)
550件の閲覧回数
Robin_Shen
Please check if it is related to the reasons mentioned in the following discussion:
If I don't give s32k312 delay, the CAN stop during operation
S32K3_HSE_BUG_RTD2.0.x
Robin
531件の閲覧回数
vikmonti7804
Hi robin,
        You can try with the board with HSE firmware installed on it and use the example code Dio_Example_S32K312, then you will see that the firmware is going into hard fault due to the function called Mcu_InitClock(McuClockSettingConfig_0);.
If i comment this function from the main file then there is no hard fault and led start toggling so my question.
How is this LED toggling without clock init?
Does HSE firmware is initializing the clock for MCU?
Please let me know these answers.
526件の閲覧回数
Robin_Shen
Could you share the S32DS version you are using and also the RTD version? So that I am able to verify if this is a problem related to a specific version of the tool.
Also, have you checked the two discussions mentioned in my last reply?
520件の閲覧回数
vikmonti7804
I am using RTD version is 4 4 0 and SW Version 2 0 3
DS version i am using Version: 3 4
I tried
Changes done in file structure Mcu_aClockConfigPB_VS_0 in the file Clock_Ip_VS_0_PBcfg.c.
Change the value from 1 to 0 for FIRC clock and DIO example code is starts to run with HSE firmware.
But i need to justify why this is happening?
what is the reason behind this ?
Please check attached image.
512件の閲覧回数
Robin_Shen
After the HSE FW is installed, the highest 3 bits(APP_CORE_ACC) of the GPR register are set to 0, which means that the application core cannot change the FIRC divider.
However, the RTD 2.0.x code does not check if it can be changed, so the system will directly enter the hard fault.
In HSE-RM, it says the FIRC divider can be modified by call the HSE service.
507件の閲覧回数
vikmonti7804
So how much is the clock frequency for core from HSE?
Does HSE FW initialize the clock ? and at what frequency?
Do we need to initialize clock additionally in application?
Please clear asap.
487件の閲覧回数
Robin_Shen
The proper operation of the HSE subsystem depends on the correct configuration of the clocks CORE_CLK, HSE_CLK, AIPS_SLOW_CLK, AIPS_PLAT_CLK, etc. Therefore, users need to follow the chapter 14.2.2.2 Clock Frequency Options for Devices of RM758223-HSE-B Firmware Reference Manual - V2.3(2.3).pdf, otherwise the HSE may not operate properly, or even HSE FW will be erased. Please initialize clock in your application.
