FlexIO use in LIN
FlexIO use in LIN
233 次查看
RunqiangCao
Hi NXP
     I am using FlexIO for LIN in S32K358. When I use the example in RTD, I meet a problem about it
    When I send LIN frame by FlexIO , the LinStatus is always tx busy and can't be ok , I hope you can tell me how to solve it
    Thank you in  advance
201 次查看
PetrS
do you have LIN transceiver connected properly? It is active and with right termination?
What is a signal seen on LIN line?
BR, Petr
