FlexCAN in loopback test
3,029件の閲覧回数
arvindupadhyay
Hi Friends,
I am using S32K144, i want some sample code to test Flex CAN in loopback mode. I have written code but it is not working.
Arvind
5 返答(返信)
2,163件の閲覧回数
lukaszadrapa
Hi Arvind,
see attached example. It is not loopback mode but it should help. Two FRDM boards are used.
Pushing SW2 on Tx board starts sending CAN message, then Rx board reply same message to Tx board.
You can configure project for Rx and Tx at line 41 in main.c.
Lukas
2,163件の閲覧回数
swatimali
I am beginner for CAN , can you please explain how should I use above attached code for CAN functionality on S32K144 Eval board ?. I have PCAN view tool how should I see data their.
Thanks & Regards,
Swati Mali
2,163件の閲覧回数
arvindupadhyay
Hi ,
Here is my sample code for LoopBack Test for FlexCAN.
GitHub - arvind747/S32K144_FlexCAN_LoopBackTest: Example code of FlexCAN loopback test
Arvind
2,163件の閲覧回数
arvindupadhyay
Hi Lukas,
Thank you for reply, I am managed to configure example code as in loopback mode and its working fine.
Arvind.
2,163件の閲覧回数
dileepbalgi
Hello Arvind,
   Can you please explain how you are able to configure the above example in loopback mode.It will be helpful if u attach the code with the reply.
Dileep
