Flashing data into S32K144 internal Flash memory by using autosar Flash driver specification
681 次查看
aimaier
I have encountered a problem when flashing data into S32K144 internal Flash memory by using autosar Flash driver specification, fashed 8bytes data into memory by calling the Fls_write() and Fls_main function and then I checked the job result by calling function Fls_getjobResult() and I got a job failed result,but strange things is the data has been stored into already and I got a failed result . The consequent write operation some times could be done and some times not! Before writing data, I have configured the Flash module properly by using EB tresos tool and I'm sure I have initialized the module before using it, so what was going on here? Anybody call tells me what's the problem is, I'll appreciate your help!
562 次查看
lukaszadrapa
in case of questions related to Autosar, it's better to enter a ticket:
http://nxpcommunity.force.com/community/CommunityContextPage
Lukas
