Failed to load falsh loader
435 次查看
shivakrishna
I am having an issue with the flash the software.
I get an error when trying to download using I-Jet.
i am using S32K312 controller.
The error message is:
Failed to load flash loader:C:\Program files(x86)\IAR Systems\Embedded Workbench 8.4 EWARM FS 8.50.10\arm\config\flashloader\NXP\FalshS32K3x2.flash
please help me to resolve this issue.
397 次查看
lukaszadrapa
Hi @shivakrishna
what kind of board do you have? Is that our EVB or do you have your own design? Was it working in the past? If it is related to I-Jet configuration, please discuss this directly with IAR.
Lukas
390 次查看
shivakrishna
hi NXP team,
Its our own design, and it was working properly in the past,
and its not issue with I-jet, with same I-jet i flashed in other boards its flashing properly,
can you please guide me how to resolve this issue.
379 次查看
lukaszadrapa
Did you try to measure all supply voltages? Is the reset deasserted after power on? Did you try to measure current consumption of good board and bad board to see if there's some significant difference (i.e. possible shortcut or something like that)?
What was the last operation / change in your software when it stopped working?
Lukas
