EB Tresos Error code 60002
801 次查看
focusdoit
Hi Community,
I met an issue when I verifed the Mcal Configuration on EB,
On Error log view,
Does anybody have a clue about it?
717 次查看
focusdoit
6 回复数
776 次查看
Julián_AragónM
Hi @focusdoit,
Is this an example from the RTD package? Could you share your version of the drivers and EB Tresos?
Julián
693 次查看
focusdoit
I just did a test on RTD SW32K3_S32M27x_RTD_R21-11_4.0.0_HF01.link,
Added Mcu module, verified, got warning 0, error 0, but when I added the DIO module , not configured it, then I try to verify the project, got
Do you know the reason? thanks
718 次查看
focusdoit
Resolved.
710 次查看
wuxianlong
@focusdoit Hi,
How did you solve it, please? I also encountered the same problem when using RTD4.0.0. But since there was no problem with generating the code, I didn't study it carefully
BRs
xianlong
649 次查看
focusdoit
Perhaps it's RTD issue , tested again, ignore the Error log view, just generate the project, then 0 errors 0 warnigns, even the Error log view was clear. FYI. : )
693 次查看
focusdoit
I just did a RTD configuration test in EB,added 2 modules:MCU and DIO, removed the DIO, then 60002 error was gone.
