Disable eMIOS from input pin via TRGMUX
462件の閲覧回数
oskarjohansson
Hi, I am trying to disable eMIOS channels from an input pin using the MCAL.
I am using S32K312 with RTD 2.0.0 D2203.
In the Port config the input pin is set to TRGMUX_TRGMUX_IN6 and in Trgmux Logic Group the hardware input is set to TRGMUX_IP_INPUT_SIUL2_IN6 and hardware output to TGMUX_IP_OUTPUT_EMIOS012_ODIS0. So far, so good I think.
Then in Pwm/ Emios Instance the Output Disable Source is greyed out and I cannot find how to activate the setting.
Oskar
2 返答(返信)
431件の閲覧回数
Senlent
Hi@oskarjohansson
I spent some time researching, and it's the same on my side, and I can't find a place to configure it.
I need to communicate with the IDE team to confirm whether this is a bug,
At present, you can modify it manually,
thanks for your report.
426件の閲覧回数
oskarjohansson
Okay! I will do that meanwhile.
Oskar
