DMAMUX Channel Configuration register SOURCE Values for S32K344
已解决
跳至解决方案
940 次查看
autolan22
I was exploring the DMAMUX register description , I couldn't found any source list for DMA Channel Source (Slot)
I have gone through all the attached excel sheets , still I was not able to see slot numbers for peripherals
Where can I get those values ???
I've found S32K144's xlsx file, where is the S32K344's DMA mapping file?
For example : FlexCAN0 source value is 54
Best Regards
autolan22
标记 (3)
1 解答
932 次查看
Senlent
Hi@autolan22
I have replied to you in your other question,
在原帖中查看解决方案
2 回复数
920 次查看
autolan22
933 次查看
Senlent
Hi@autolan22
