Configure S32K116 on EB Tresos
Embedded_novice
When I configure the module Resource in EB my iS32K116, when I configure the Port module and generate the code, I will prompt that the relevant .m file cannot be parsed, but when I select the chip in the Resource as any other chip, the parsing of the Port module is successful, how can I solve or troubleshoot this problem?
And I have tried reinstalling the MCAL installation package, as well as using a version of the order, the situation has not changed.
EB Version:28.0.0
MCAL Version:S32K1XX_MCAL4_3_RTM_1_0_4Snipaste_2023-09-18_14-10-21.png
NamLee
Hi Rooki_NXP,
Can you share me the link of the MCAL that you entered?
I enter this link on NXP
Thank you,
Nam.
NamLee
Hi Rooki_NXP,
This issue already found out and report in our internal ticket MCAL-27236.
The root cause comes from the CRYPTOMANIFEST.MF in the Port plugin and it does not have information for "generate_PC/Port_S32K116_Resource.m", S32K142w and S32K144w
Root Cause Details: Missing configuration files in SIGN_FILES (NA for NewFeature)
Proposed Solution: Update missing configuration files in SIGN_FILES
Duplicated resource in generate_PB. Need to remove and replace by:
generate_PC/Port_S32K142w_Resource.m
generate_PC/Port_S32K144w_Resource.m
The issue was fixed in MCAL 4.3 RTM 1.0.5, i already tested and it's running well, please help me to use this release.
Thank you,
Nam.
Embedded_novice
I only found MCAL 4.2 RTM 1.0.5
Embedded_novice
Can you provide a download link?
NamLee
Hi Rooki_NXP,
Please try to search MCAL package in NXP website. You can see the latest release of MCAL 4.3 is version 1.0.5 in Jul 31.
Thank you,
Nam.
Embedded_novice
Embedded_novice
NamLee
Hi Rooki_NXP,
Thank you,
Nam.
Embedded_novice
Yes, I used the same link as you showed, but after clicking download, the interface was blank. I also tried using different browsers and devices, and even tried other IPs using VPN, but they were all blank.I am not sure if I alone have this problem or if others will also have the same problem
But I found this MCAL from other links and built a testing project, which did solve my problem. Thank you very much for your help and wish you a happy life.
NamLee
Hi Rooki_NXP,
Sure, you're welcome!
If you can share the link that you found in here, it'd be helpful for other people who may have the same issue.
Thank you,
Nam.
Embedded_novice
I am at the top right corner of the homepage of NXP's website :MY NXP Account->software Licensing and support->View accounts,and in Software&Support->Recent Product Releases,Select in the date selection box:Last 90 Days,Found this MCAL there.No offense, but NXP's data search seems a little confusing to me.
Thanks again for your help.
NamLee
Actually i usually enter the same way to download packages as you mentioned MY NXP Account->software Licensing and support->View accounts,and in Software&Support.
But i'm using NXP Employee account.
Btw, thanks for your information.
Nam.
NamLee
Hi Rooki_NXP,
I just try to reproduce in my side, and the issue comes from the fact that the CRYPTOMANIFEST file (in META-INF folder) doesn't sign derivative K116 PC (PreCompile). So it seems like a bug of signing process of license file with NXP side.
The PB (PostBuild Generate) can be executed, but you have to configure all modules as PB so it's not a clear solution.
One of another solution is signing again in your side, but i'm contacting to verify this solution first, so just inform to you like that.
Please wait me for a bit longer,
Thank you,
Nam.
Embedded_novice
Thank you for your help.
NamLee
Hi Rooki_NXP,
Please help me to use the EB Tresos version 24 as mentioned in Release Notes.EB_Version.png
Thank you,
Nam.
Embedded_novice
It's still a bad situation. Do you have any other solutions?Snipaste_2023-09-19_10-08-52.png
Embedded_novice
Thank you for your suggestion. I will try this method
