Code generation malfunctions in Flexio_Pwm_Ip_Cfg.h
390件の閲覧回数
Gwihan
Q.1: Is there anyone having the same problem as below?
"generate/include/Flexio_Pwm_Ip_Cfg.h:54:10: fatal error: Flexio_Pwm_Ip_BOARD_InitPeripherals_PBcfg.h: No such file or directory"
I thought this message means I have done something wrong. But, this problem is easily solved if I correct header include statement manually (to Flexio_Pwm_Ip_PBcfg.h).
Q.2: What is wrong with template file (of Flexio_Pwm_Ip_Cfg.h) or my configuration?
(I have check my c-code. It will run just fine if the wrong include statement is fixed manually.)
369件の閲覧回数
Robin_Shen
Please try to test whether the latest S32K3 RTD 4.0.0 has fixed this issue.
Robin
4 返答(返信)
370件の閲覧回数
Robin_Shen
Robin
265件の閲覧回数
Gwihan
Yes, this has fixed the issue.
Though I had to deal with few problems aroused by difference between two versions, it is worth moving onto RTD 4.0.0.
364件の閲覧回数
Gwihan
Is any of RTD 4.0.0 supports S32K312_172MQFP?
RTD I got supports s32k312_hdqfp172.
359件の閲覧回数
Robin_Shen
Yes. These two packages are actually the same, only the name was changed from MAXQFP to HDQFP.
