Clock config
Clock config
2,588 次查看
rajesh057
Hi ,
I am trying to config clock 80 Mhz ,my external clock 16 Mhz ,I have configured like below pic ...getting TIME_OUT FROM return status from
CLOCK_SYS_SetConfiguration() function .
Rajesh K
5 回复数
2,374 次查看
dianabatrlova
Hi Rajesh,
The warning informs you that the SPLL_CLK frequency must be between 90 MHz and 160 MHz.
So, I recommend you to set the SPLL_CLK = 160 MHz and for SYS_CLK set SPLL_CLK/2. After that, you reach SYS_CLK = 80 MHz without warnings.
I hope it helps you.
If you have any questions, let me know.
Diana
2,374 次查看
rajesh057
hi Diana ,
Thanks for answer .
its is not related to the software issue its hardware problem .
on more problem I am facing with Latest SDK os millisecond function not working .interrupt not triggering.
Rajesh Kota.
2,374 次查看
dianabatrlova
Hi Rajesh,
However, I have seen in your attachment a warning below because the PLL frequency is not within the range.
Regarding your second question, could you please provide more information such as a piece of your code settings?
Thank you.
Diana
2,374 次查看
rajesh057
Hi Razvan-nicolae Tilimpea
Please find the following attachment.
2,374 次查看
razva_tilimpea
Can can you mention what is the SDK version used in your project?
Razvan
