Change LPSPI CCR register
Jembed
Hello NXP team,
In the reference manual of S32K1 (S32K-RM) there are two contradictory statements about the possibility of changing the CCR register. As highlighted in the images below, first it says that to change this register, the module must be disabled. And elsewhere it says that the module should not be at busy state.
The question is that, is it possible to change the CCR register when the module is enabled but is not busy (it is at idle state)?
Jembed
Tags (4)
danielmartynek
Hi @Jembed,
I have requested clarification in this matter and a fix of the discrepancy.
I will update the case as soon as I have more information.
For now, please disable the module whenever you change the register.
If you use the RTD drivers, the module is disabled by the LPSPI driver before it writes to the register.
