CMP Round Robin in Run mode for S32K148
1,339 次查看
kart
Is there any Example reference code for using CMP Round Robin mode in Run mode.
I want to monitor 3 Channel inputs(INP) and compare with the Dac reference voltage(INN).
Is it possible to monitor the CMP_C2[CHnF] and CMP_C2[ACOn] in the ISR of Round Robin to identify the Change of input state for individual channels?
When CMP_C2[RRIE] is enabled, Is there a separate ISR for the CMP Round Robin similar to CMP0_IRQn?
kart
1,323 次查看
Robin_Shen
Hi kart,
Please refer: Example S32K144 CMP Round-robin S32DS2.0
Hope it helps.
Robin
1,300 次查看
kart
Hi Robin,
The Example uses the VLPS mode and LPTMR clock source is used for Comparator round robin clock.
Can we use Round robin mode in RUN mode with SIRC clock source for Comparator round robin clock?
Round Robin implementation is discussed in "45.1.5 CMP trigger mode" of S32K Reference Manual "https://www.nxp.com/webapp/Download?colCode=S32K1XXRM"
Last 2 steps in Round robin implementation are explained as follows:
I do not want to use the Low power mode as discussed in (3) and use a different clock other than LPTMR as shown in (2).
1,281 次查看
Robin_Shen
Hi kart,
I am sorry to tell you that the CMP round robin/trigger mode is available only if the MCU is STOP1 or VLPS and LPTRM must be used to trigger the CMP comparisons.
I am afraid you need to implement the round robin in software with CMP module and an additional timer. Based on the overflow interrupt provided by timer you have to change the channel used for comparison and to check if the output value of the CMP matches expected value or not.
Robin
