C40_IP Write Flash - Issue in the 2nd time writing in the memory - S32K344
663 次查看
Salomi
Hello Team,
I am trying to write the data using C40_IP  in the memory address for the second time. It is not writing in the memory , only the previous write data remains in the memory.
Kindly provide me the guidelines to solve this issue.
Thanks in advance
10 回复数
458 次查看
davidtosenovjan
Have you tried example C40_Ip_Example_S32K344 from latest RTD version?
Erase operation calling return success operation but content is not erased.
Don't you have enabled cache for that area?
442 次查看
Roshani
Hello @davidtosenovjan
I have tried the same approach which you have mentioned. But still, I could not be able to write the 2nd time in memory. Please provide your suggestion.
Thanks in advance!
380 次查看
Roshani
Hello @davidtosenovjan ,
Please provide your suggestions for the issue.
370 次查看
davidtosenovjan
My suggestion is to disable the cache (if it's enabled, which you still haven't answered).
396 次查看
davidtosenovjan
Have you disabled cache how I already asked?
563 次查看
Salomi
Hi @davidtosenovjan
I have tried with the C40_IP_Example code from NXP community. Please find the attachment for your reference.
493 次查看
Roshani
Hello @davidtosenovjan,
The sector erase is not happening properly for me. Because of that I am unable to write the data 2nd time. Your quick reply will be very much appreciated.
Thanks in advance!
641 次查看
davidtosenovjan
Have you performed erase operation in between?
602 次查看
Salomi
I have tried with both the option with Erase and Without Erase between write operation.
578 次查看
davidtosenovjan
Which example this question is related to?
