C40_IP Write Flash - Issue in the 2nd time writing in the memory - S32K344
1,049件の閲覧回数
Salomi
Hello Team,
I am trying to write the data using C40_IP  in the memory address for the second time. It is not writing in the memory , only the previous write data remains in the memory.
Kindly provide me the guidelines to solve this issue.
Thanks in advance
10 返答(返信)
844件の閲覧回数
davidtosenovjan
Have you tried example C40_Ip_Example_S32K344 from latest RTD version?
Erase operation calling return success operation but content is not erased.
Don't you have enabled cache for that area?
828件の閲覧回数
Roshani
Hello @davidtosenovjan
I have tried the same approach which you have mentioned. But still, I could not be able to write the 2nd time in memory. Please provide your suggestion.
Thanks in advance!
766件の閲覧回数
Roshani
Hello @davidtosenovjan ,
Please provide your suggestions for the issue.
756件の閲覧回数
davidtosenovjan
My suggestion is to disable the cache (if it's enabled, which you still haven't answered).
782件の閲覧回数
davidtosenovjan
Have you disabled cache how I already asked?
949件の閲覧回数
Salomi
Hi @davidtosenovjan
I have tried with the C40_IP_Example code from NXP community. Please find the attachment for your reference.
879件の閲覧回数
Roshani
Hello @davidtosenovjan,
The sector erase is not happening properly for me. Because of that I am unable to write the data 2nd time. Your quick reply will be very much appreciated.
Thanks in advance!
1,027件の閲覧回数
davidtosenovjan
Have you performed erase operation in between?
988件の閲覧回数
Salomi
I have tried with both the option with Erase and Without Erase between write operation.
964件の閲覧回数
davidtosenovjan
Which example this question is related to?
