100 pin versus 64 pin FS32K144
1,376件の閲覧回数
joshua1
We are looking to use the FS32K144 for a new product. When looking in the IO_Signal_Descritption_Input_multiplexing table we see that there is a package 64lqfp and a package 100lqfp.
What is the difference between the 64 pin and 100 pin packages?
Thanks!
1,290件の閲覧回数
dianabatrlova
Hi Joshua,
You can look at the Hardware Design Guidelines for S32K1xx Microcontrollers
Table 1. Power domains and decoupling capacitors
https://www.nxp.com/docs/en/application-note/AN5426.pdf
Also, the difference is in the number of ADC1 channels
However, you can look at the PeripheralSummaries sheet in the S32K144_IO_Signal_Descritption_Input_multiplexing document.
I hope it helps.
Diana
