Hi guys,
I'm using S32G-VNP-RDB2, i have inserted the SD card which contains Linux OS, I'm using ssh by using the IP of RDB2. But where can I get the password? I tried to find in the documents, but nothing.
Thanks for your support!
The Linux OS provided in the SD card does not have a password for the user, you need to create a password in order to use it with ssh.
The following community post talks about how to create a password for the user you need. This post is related to S32V, which uses "vision" as its user. For the S32G2, "root" is the user you begin with.
Solved: what's the default login name and password of pre-... - NXP Community
Please, let us know if this information was helpful or not.
