in ETH2CAN , How to distinguish between standard frames and extended frames
NumbLucas
in the  UDP frame stucture,How to distinguish between standard frames and extended frames
Bio_TICFSL
This appnote might helps:
https://www.nxp.com/docs/en/application-note/AN13423.pdf
