build S32G274 BSP35 Yocto'issue
2,579件の閲覧回数
teddywang
hi sir
   I try to build S32G274 BSP35 Yocto in China,when I repo the github,the issue is under bold line,how to modify the issue,thanks
vmuser@ubuntu:~$ chmod a+x ~/bin/repo
vmuser@ubuntu:~$ PATH=${PATH}:~/bin
vmuser@ubuntu:~$ cd fsl-auto-yocto-bsp/
vmuser@ubuntu:~/fsl-auto-yocto-bsp$ repo init -u https://github.com/nxp-auto-linux/auto_yocto_bsp -b release/bsp35.0
File "/home/vmuser/bin/repo", line 1292
comment_line = re.compile(rb"^ *#")
SyntaxError: invalid syntax
vmuser@ubuntu:~/fsl-auto-yocto-bsp$ python --version
Python 2.7.17
9 返答(返信)
2,524件の閲覧回数
MayanksPatel
Hi @teddywang,
Thank you for reaching out to us.
There is an issue with the repo you are using and that might not be compatible with this.
Please perform the steps,
mkdir ~/bin
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
PATH=${PATH}:~/bin
The steps provided to you are validated and I tried the same and it works.
Hope this helps you.
Mayank S Patel
2,513件の閲覧回数
teddywang
the qinghua repo is curl https://mirrors.tuna.tsinghua.edu.cn/git/git-repo -o repo.whether you meet the same question?
2,514件の閲覧回数
teddywang
hi Mayank
   Sorry,In China we could not use google repo,so we have to us qinghua sourcing for working arround,whether has another linker could repo?thanks
2,504件の閲覧回数
MayanksPatel
Hi @teddywang,
There are two options here
1. Use a VPN and follow the steps mentioned in the BSP UM.
2. Perform minor changes in the repo file by opening it in a text editor. Please find the attached image which suggests a change performed in the repo file.
NOTE: Change performed at Line Number 1292 which is the same line number you were facing issue.
Hope this helps.
Mayank S Patel
2,488件の閲覧回数
teddywang
hi
   1:I have refered your attachment and modify repo file to under line,I found the repo link to https://gerrit.googlesource.com/git-repo
   2:whether could modify repo file to link "curl https://mirrors.tuna.tsinghua.edu.cn/git/git-repo"?
   thanks
@classmethod
1291 def from_data(cls, data):
1292 comment_line = re.compile(br"^ *#")
1293 strip_data = b"".join(x for x in data.splitlines() if not comment_line.match(x))
Downloading Repo source from https://gerrit.googlesource.com/git-repo
fatal: Cannot get https://gerrit.googlesource.com/git-repo/clone.bundle
fatal: error [Errno 111] Connection refused
fatal: double check your --repo-rev setting.
fatal: cloning the git-repo repository failed, will remove '.repo/repo'
2,453件の閲覧回数
MayanksPatel
Hi @teddywang,
First, download the repo from https://mirrors.tuna.tsinghua.edu.cn/git/git-repo and this will be downloaded in the /home/<user>/bin directory.
Open the downloaded repo file in the editor and perform the changes.
1. Remove the already created folder fsl-auto-yocto-bsp folder.
2. again create the same folder.
you have earlier performed repo init using the google repo link and .repo hidden folder created in the directory fsl-auto-yocto-bsp. by deleting the already created folder your issue will be resolved.
Hope this helps.
Mayank S Patel
2,393件の閲覧回数
teddywang
hi sir
  I don't clear your comments,whether I open the repo file with note editor and remove google's link?
  the attachment is my repo download curl https://mirrors.tuna.tsinghua.edu.cn/git/git-repo
2,327件の閲覧回数
MayanksPatel
Hi @teddywang,
You need to delete the folder fsl-auto-yocto-bsp and connect to VPN which is outside of China and again follow the steps mentioned in the UM #section 3.1.1.
I confirmed with the NXP team in China and they were using a VPN for this.
Mayank S Patel
2,530件の閲覧回数
teddywang
the repo that I use qinghua source.curl https://mirrors.tuna.tsinghua.edu.cn/git/git-repo -o repo
