Where to get HSE 0.2.22.0 firmware for S32G2 platform based on SDK BSP38 release
hittzt
Senior Contributor I
I noticed that, the SDK BSP38 has been released, and in the release note, the "S32G274A
Rev 2.0" boards(S32G-VNP-RDB2 and S32G-PROCEVB-S) have been tested with "HSE Firmware 0.2.22.0".
But I checked the avaliable HSE firmware resources for BSP38, and did not fine the firmware for "S32G274A Rev 2.0" boards. There is only HSE 0.2.22.0 firmware for Rev 2.1.
Would you please help to tell where can get the HSE 0.2.22.0 firmware for S32G2 Rev 2.0 platform?
Zhantao
Daniel-Aguirre
We have received the following update:
"HSE firmware x.2.22.0 does not support S32G274A cut 2.0"
It seems that there is a mistake under the documentation, at least to this day. The team is aware and has noticed the respective team for the correction. We do apologize for the inconvenience.
Please, let us know.
Daniel-Aguirre
We understand that HSE x.2.xx.x should not be compatible with silicon rev 2.0, but we are seeing the information you are referring to under the BSP38.0 release notes.
Let us confirm the reason of this note under the release notes.
