My company bought evaluation kit S32G-VNP-EVB3. The processor is NXP S32G399A rev. 1.0. I followed the steps in the S32G3_LinuxBSP_31.0_user_manual ("write image" section of the document) to create a bootable sd card with the yocto .sdcard format.
I made sure the jumper settings are set currently as per S32G3_LinuxBSP_31.0_user_manual for qspi boot. ("boot from parallel RCON" section of the document). The boot did not go through and the following is what I see on the uart console.
NOTICE: Reset status: Power-On Reset
PANIC at PC : 0x0000000034306740
Am I missing any step?
Has the problem been solved? I had the same problem starting with EMMC
