S32G3 Flexray / LLCE Flexray_43_LLCE_Ip_ReceiveInd
132件の閲覧回数
jlai
For the S32G3 Flexray LLCE IP drivers 1.0.7, it is not clear how these are supposed to be used.
For example, for the Flexray_43_LLCE_Ip_ReceiveInd function, is this function supposed to be called in a polling fashion with a single message buffer index? If we have a 10 message buffers that corresponds to 10 frames, do we call the Flexray_43_LLCE_Ip_ReceiveInd on each ID in a loop (along with calling Flexray_43_LLCE_Ip_GetTransferStatus?
Is there an example of using the Flexray_43_LLCE_Ip_ReceiveInd directly with multiple message buffers?
タグ(3)
116件の閲覧回数
Daniel-Aguirre
We might be misunderstanding the overall inquiry. If so, we do apologize. Below will be some comments on regards on regards of your questions:
[DA]: The following is told under Flexray_43_LLCE_Ip.h:
For which, it is to be used under individual buffers.
[DA]: For the available examples under LLCE, we understand that using the Flexray_43_LLCE_Ip_ReceiveInd function is not recommended, since the function Fr_43_LLCE_ReceiveRxLPdu is the one being used.
[DA]: The only available examples for FR are those available under the LLCE package, which we understand uses the function told under the previous comment.
Please, let us know.
