Network error on s32g QNX7.1
lewis123
Dear NXP,
I am running QNX7.1 on S32G-VNP-RDB2, but there are problems with the network.
The NIC dwc0 is identified after the system starts, I configured a valid ip for it.
But it can not ping other machines(return info: "ping: sendto: Host is down"), and no machine could ping the board.
Could you please suggest, is there any other work that needs to be done here.
Thank you for your support.
Bio_TICFSL
Check with QNX since this works with the NXP BSP,
