IPCF sample application
342件の閲覧回数
SriramVenkat
I tried compiling the IPCF application framework given for NXP S32 RTD running on Cortex-M7 core of NXP S32 platform. The application was builded for bare-metal. To access the shared memory whether any other framework is required other than the IPCF_4.6.0_D2205.
Also, is there any flashing procedure available for Cortex-M7 core?
320件の閲覧回数
Daniel-Aguirre
We might be misunderstanding the request. Below will be some comments.
IPCF is available on both the bare-metal application inside the M7 core (with the examples provided under the IPCF package) and linux. Under the IPCF example (the one for M7 core) a "description.txt" is provided, in which detailed steps are provided on how to run the example application.
Also, which RTD/BSP versions are you using?
Please, let us know.
