How can the M and A cores be packaged into A burning image
650件の閲覧回数
jianqun
Today we verified M7 starting from QFLASH and SD, M7 can start from QFLASH and SD alone,Core A now boots from an SD card ,but the dip switch for starting from QFLASH and SD is different on RDB board,How do we get M and A to start at the same time, or do we start M and then pull up A,How do we package both M and A cores into the same image file
2 返答(返信)
635件の閲覧回数
Bio_TICFSL
Hello jianqun,
You can't burn in the same package, you can create a new repository in yocto to create all the core M stuff and burn your S32, then run the M0.
624件の閲覧回数
jianqun
There are detailed documentation, our development environment is S32DS
