HSE enable secure boot, when debug HSE_DEMOAPP_S32G2XX_0_2_22_0, the FSR is exception
250 次查看
Vicky1235
Hello:
I use HSE_FW_S32G2XX_0_2_22_0 to enable secure boot, when I debug HSE_DEMOAPP_S32G2XX_0_2_22_0 demo, after finishing the demo, I found the FSR value is 0x4E400000, the HSE_STATUS_INIT_OK bit was cleared, MUs are disabled.
I used S32G234M chip.
219 次查看
Daniel-Aguirre
Can you let us know which silicon revision are you using?
Can you let us know which steps did you follow of the HSE_DEMOAPP? Under which chapter?
Please, let us know.
