GOLDBOX-3 Ubuntu S32G-VNP-RDB3 - Networking
692 次查看
ankitv
I am using BSP 38 to build Ubuntu for Goldbox3. After a successful build, I am not able to provide internet connection to my Goldbox.
During Startup I see the following error:
bluebox@ubuntu-s32g399aevb3:~$ [ 611.061548] s32cc-dwmac 4033c000.ethernet eth0: no phy found
[ 611.061567] s32cc-dwmac 4033c000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 611.069040] s32cc-dwmac 4033c000.ethernet eth0: no phy found
[ 611.069056] s32cc-dwmac 4033c000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 611.076265] s32cc-dwmac 4033c000.ethernet eth0: no phy found
[ 611.076279] s32cc-dwmac 4033c000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 611.083428] s32cc-dwmac 4033c000.ethernet eth0: no phy found
[ 611.083442] s32cc-dwmac 4033c000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
The same error keeps on printing on the terminal when left idle.
Can you please advise which LAN port should I use to provide Internet and how to solve the above error. I tried building Ubuntu 20.04 and Ubuntu 22.04. Both gives me same error. Thanks.
-Ankit
7 回复数
558 次查看
chenyin_h
Hello, @ankitv
You are welcome, we feel glad to hear that the issue is fixed
Regarding to the network interface:
  1. By default. the 100Base-TX directly connected to the SJA1110 switch, you may use it by typing ifconfig pfe0 x.x.x.x in Linux.
  2. 1x2500base-T is connected to SerDes1_lane1, by default, it is mapped to the  PFE_MAC1, as a result, you may use it by typing ifconfig pfe1 x.x.x.x.
Best Regards
Chenyin
601 次查看
dennis-voyager
Hi @ankitv
Thanks for the question, I'm having the same issue.
I am using those commands to build Ubuntu-ros for Goldbox2.
source nxp-setup-alb.sh -m s32g274aevbubuntu
bitbake fsl-image-ubuntu-ros
[ 4442.216923] s32cc-dwmac 4033c000.ethernet eth0: no phy found
[ 4442.216931] s32cc-dwmac 4033c000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
Any suggestions and information are welcome, thanks in advance.
Dennis
587 次查看
ankitv
Hi @dennis-voyager
Please verify if your goldbox is based on s32g274aevb and then use the correct command.
Replacing s32g399aevb3 to s32g399ardb3 worked for me as my goldbox is based on ardb3 and not aevb3. Thanks
-Ankit
558 次查看
dennis-voyager
I get it, thanks for your suggestions.
653 次查看
chenyin_h
Hello, @ankitv
Goldbox3 is based on s32g399ardb3, not s32g399aevb3, as a result, according to the section3.1.3 from “Linux BSP 38.0 User Manual for S32G3 platforms”:
source nxp-setup-alb.sh -m s32g399ardb3ubuntu
bitbake fsl-image-ubuntu-base
After all necessary images built, use them on Goldbox3 and have another try.
588 次查看
ankitv
Hi @chenyin_h
Yes, it is working now. Thanks for sharing the information.
However, I found that only 4 ports of 1000Base-T x2 ports are working. How do I enable the 1000Base-T/2.5GBase-T x1 and 100Base-TX x1ports ? Thanks
-Ankit
689 次查看
ankitv
Here is a screenshot of the above error
