Hello NXP:
I saw in S32 LLCE module,we can config can message routing by EB Tresos or S32DS Ide,and I tested the CAN2CAN demo successfully. Then I want to know if there is a way to configure can signal routing ?
Hello, @LeeHua
Thanks for the reply and sorry for the delay.
The signal routing is not supported by S32G LLCE, and the message that does not meet the route table would be dropped by the LLCE.
You may reference the LLCE firmware user guide for any details.
Hope it helps.
Best Regards
Chenyin
Thanks for your replay@chenyin_h:
I want to know if I config an unrouted can message in LLCE module, when BCAN receive this message , where it will be sent? If I want to handle this message at Host side, How can I reach this message ?
Hello, @LeeHua
Thanks for the questions.
May I know your detailed working scenario or purpose for the signal routing?
For signal routing itself, may I know if you are referring to the signal gateway feature defined in Autosar 4.4 CP?
Best Regards
Chenyin
