Debugging BL2 on S32G RDB hardware
yellapu_anishkh
I am trying to debug bl2. loaded bl2 binary on to target and continues loop with a variable.
then attached using lauterbach and loaded bl2.elf, bl2 compiled with DEBUG=1 option, which
means symbols are enabled, but when loaded all symbols are not loaded. Please point to me, if i
am missing anything.
below is the script used.
sys.cpu S32G399A-A53
core.assign 1
SYStem.config.debugporttype JTAG
SYStem.Option TRST OFF
sys.attach
Data.Load.Elf bl2.elf  /GLOBTYPES /NoClear /NoCODE
break
list
ENDDO
Tags (3)
