Boot mode of the S32G
918件の閲覧回数
maiwl
CAN the BootRom of the S32G2 be started in CAN mode besides the serial port mode?
855件の閲覧回数
Daniel-Aguirre
For what it is provided under the S32 Flash Tool User Guide, those 3 "CAN device name" are the ones provided.
Please, let us know.
4 返答(返信)
889件の閲覧回数
Daniel-Aguirre
Under the S32G2 Reference manual, the following is told [Page 1341, S32G2 Reference Manual, Rev. 7, February 2023]:
"In Serial Boot mode, BootROM programs the HSE_H SWT for a 60-second timeout, then continuously polls for activity on any of the available interfaces:
•CAN
•UART
If no activity is detected, the timer expires and the core is reset. BootROM sequentially checks for activity on all available interfaces and selects the first serial interface that it identifies as active as the download interface."
If you want to use CAN for the serial download, then the LIN/UART interface should not be used, for it to detect activity on CAN and start using CAN.
Since this is related to the BootROM, you cannot disable one or the other.
878件の閲覧回数
maiwl
Thank you very much for your reply
Is there documentation describing how to download it by CAN? I only know that downloading via UART is using S32FlashTool
871件の閲覧回数
maiwl
I found some information about CAN download. Do you only support CAN devices from these three manufacturers (VectorXL Kvaser IXXAT)?
856件の閲覧回数
Daniel-Aguirre
