Added support for GD25LQ128D qspi flash
303 次查看
shiyiheng
Now I am developing based on BSP34 branch and want to add GD25LQ128D qspi flash support under uboot. The device tree configuration is as follows, but I failed to read JEDEC, and I found that only macronix and micron products are supported based on this branch. What do I need to do if I want to support GD25LQ128D?
255 次查看
Bio_TICFSL
Yes, you have to add you hardware to the device tree and create the drivers is needed it, but the BSP include driver for SPI you must check it.
256 次查看
Bio_TICFSL
