S32K3 with pflash erase/write operation while dlfash configured as simulated e2prom
652件の閲覧回数
cfyywcc
HI NXP expert team:
I have an S32K314 board with AUTOSAR 4.2.2, we've configured the DFLASH as simulated e2prom,and it works fine!
Next, I plan to develop soft a/b upgrade function, you see, by which I can upgrade B partition(BLOCK3-4) when AUTUSAR runs in A parition(BLOCK1-2) online.
But I just don't know how to configure the pflash erasable/writable since it seems that AUTOSAR has already configured the low level fls interface with dflash.
So, my question is: what can I do to approach the purpose?
Deeply appreciate your sincere help!
タグ(1)
5 返答(返信)
550件の閲覧回数
Nhi_Nguyen
Hi @cfyywcc ,
You means that you want to run multicore?
Nhi
473件の閲覧回数
cfyywcc
No, S32K314 is single-core with AUTOSAR 4.2.2. and we can only config dflash operation on it with Davinci tool, so if I want to operate(erase/write) dflash, OK, AUTOSAR has already support it natively,but based on this if I want to operate pflash on AUTOSAR furtherly , no way, right?
468件の閲覧回数
Nhi_Nguyen
Hi @cfyywcc ,
What package are you using? As far as I know, dflash and pflash will be support to configure in driver. This is for pflash.
Nhi
463件の閲覧回数
cfyywcc
Logically dflash will be configed as nvm usage, but if I also config pflash as bootable B partition of full a/b solution, maybe I update B partition at the same time AUTOSAR will refresh some nvm item too, conflict occurs,right?
So, how can I do now?
446件の閲覧回数
Nhi_Nguyen
Hi @cfyywcc ,
As far as I know, conflict just occur when you touch to same regions. pflash and dfash are on difference regions. In configuration, there is overlap error when you try to configure same regions.
Nhi
