How to delete "Sources" folder in SDK project
AnhNguyenDuc
I have a project on S32DS version 2018.R1 for S32K144.
I want to use "src" instead of "Sources", so I delete "Sources" folder. But when I rebuild project, the "Sources" folder automatically create again. Can I delete it ?
namnguyenviet
As far as I know, it's not possible. However, you can ignore to build the source code in the Source folder, or whichever folder, by right click to that folder >> Resource Configurations >> Exclude from Build..., then choose the appropriate configuration that you want to exclude the folder.
Nam
