So if I set a GPIO direction as 'Input' in the pin configuration. And I want to change its direction to 'Output' at some time during the program is running.
Should I use the API below?
If so, should I set the 3rd param as 0 or 1 for 'Output'? Is there any manual about this?
I'm using S32K312 RTD v2.0.1
Jetty
解決済! 解決策の投稿を見る。
yes ,you can use this function to change GPIO direction.
you can read this function then you will easily find that,set 0 ->In,set 1->Out
