I'm trying to write a SCons script to build my project, which was originally built in S32DS.
The project built fine with the Microsoft Visual C++ compiler.
However, after specify the compiler PATH and the compiler powerpc-eabivle-gcc to use when building the project( that's the only environment setting I changed for the build), I got an error from powerpc-eabivle-gcc for every header file folder I include with CPPPATH, that there is no such file or directory.
I'm wondering if there's any special settings I need just for this compiler. Thanks for any suggestions/help:)
Ruonan
Could you please write more detail ? Especially command line switches and console output.
