cannot execute binary file: Exec format error..how do u solve this??
varun_kumar
I my getting following error, I'm not able to execute .elf file in both via terminal and vision sdk.
Error in final launch sequence
Failed to execute MI command:
-exec-run
Error message from debugger back end:
During startup program exited with code 126.
Thank you in advance
Tags (3)
jiri_kral
Um, from your console it looks that target is linux. So - what is your EVB? The uname -a output doesn't look familiar for me. Aren't you trying execute .elf file on your Linux host machine instead on EVB?
Jiri
jiri_kral
what is your target configuration? Baremetal or Linux? In my opinion you are trying start baremetal .elf file on EVB running on Linux.
Jiri
varun_kumar
you can see the debug config and followed by after debugging
