SPI - Clock & Chip select timing configuration problem
1,087件の閲覧回数
Riyasma07
In SPI configurator, when I try to change the timing values for Clk2Cs, Cs2Clk & Cs2Cs from 0.000001 sec to 0.00001 sec, I'm facing an error.
But when I hover over the timing fields, it shows the timing can be set in the range of 100ns to 0.0001 sec.
10 返答(返信)
883件の閲覧回数
Riyasma07
Hi @VaneB, Seems like it is causing problem with code. I've set the timing as 0.00003 sec and checked, there is no response from the slave.
855件の閲覧回数
VaneB
Hi @Riyasma07
Are you using an external device or is it connected to other SPI modules of the S32K3? Are you using the example code?
852件の閲覧回数
Riyasma07
Hi @VaneB ,
Yes, we are using an external device and not using example project.
835件の閲覧回数
VaneB
Hi @Riyasma07
Could you share an image of the signals coming out from the S32K3?
810件の閲覧回数
Riyasma07
Hi @VaneB,
The screenshot of signals from S32K3
792件の閲覧回数
VaneB
Hi @Riyasma07
The signs seem correct, but to make sure the problem is not caused by S32K3, please try testing the SPI example with the settings you require.
1,045件の閲覧回数
VaneB
Hi @Riyasma07
Sorry for the late response, due to workload my response was delayed.
Which RTD version are you using? Also, please provide your clock configuration.
B.R.
VaneB
1,041件の閲覧回数
Riyasma07
Hi @VaneB ,
I'm using RTD Version 3.0.0
The clock configuration is
and I'm using SPI0
917件の閲覧回数
VaneB
Hi @Riyasma07
Sorry for the delay.
I had verified this situation and the cause of the problem looks to be related to S32DS and not for a wrong configuration. The error should not cause any problem with your code.
1,064件の閲覧回数
Riyasma07
@VaneB  Any updates?
