P.expert not compiling ITOA
664件の閲覧回数
nishantsood
Hi Guys,
So, I'm working with CAN and Uart here, I have 2 projects:
1) project created from examples that is the flexcan_encrypted_s32k144 and,
2) A custom project created with Processor expert added.
Note: 1) Both of the projects have EAR SDK 0.8.6 SDKs against which they are being compiled.
          2) Same chunk of code is working fine in the flexcan_encryp example based project but the same is NOT WORKING on custom project with added PE
          3) ITOA is not getting compiled (says "undefined reference to ITOA"!!)
          4) All the components are configured correctly, interrupts, clocks, can controllers, lpuart etc (even I copied and "generated code" all times!)
When the same SDK is being with same setup and same code used why am I getting all these differences in  execution!?
527件の閲覧回数
martin_kovar
EWL library, which is by default used in the projects does not support this function. You must switch your project into NewLib. Please check the figure below
Martin
