Build error in S32DS for ARM 2018.R1
807件の閲覧回数
leekate-b45752
Hello Team,
The customer tried to build the example project files in S32 DS, the errors occurred as attachment.
I tried to do Project > Clean, and switch the work space, also I checked the C/C++ Build Settings in Properties, but there is no difference.
Could you provide advice for this issue?
Kate Lee
タグ(2)
713件の閲覧回数
jiri_kral
can you attach build Console output? I'm assuming that Processor Expert code is generated successfully, right?
Jiri
